Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
While the switch is pushed forward, pull the cover away from the camera.
To remove batteries, simply allow them to fall out of the camera.
Use a fingernail to lift the clock battery out of the camera.
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
Open the battery cover.
Using the iFixit opening tool, push up gently around all edges of the camera.
7 outras pessoas executaram este guia.
Um comentário
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
