Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
You will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
O que você precisa
Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
Remove the two screws located on the other side of the camera using a magnetic screwdriver
Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
Open the battery cover.
Using the iPod tool, push up gently around all edges of the camera.
7 outras pessoas executaram este guia.
Um comentário
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
