Introdução
You will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
O que você precisa
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
8 outras pessoas executaram este guia.
Um comentário
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
