Ir para o conteúdo principal
Canon PowerShot A590 IS Back Cover Replacement
O que você precisa
  1. Canon PowerShot A590 IS Back Cover Replacement, Batteries: passo 1, imagem 1 %32 Canon PowerShot A590 IS Back Cover Replacement, Batteries: passo 1, imagem 2 %32
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS Back Cover Replacement: passo 2, imagem 1 %32
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Back Cover Replacement: passo 3, imagem 1 %32
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS Back Cover Replacement, Back Cover: passo 4, imagem 1 %32
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot A590 IS Back Cover Replacement: passo 5, imagem 1 %32
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Canon PowerShot A590 IS Back Cover Replacement: passo 6, imagem 1 %32
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Canon PowerShot A590 IS Back Cover Replacement: passo 7, imagem 1 %32
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
Conclusão
7 outras pessoas executaram este guia.
Zach
Membro desde: 10/11/10
281 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 9-19, Regan Fall 2010 Membro de Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
Membros da 4
Autoria de 14 guias
Um comentário
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
Alice Reed - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 8,547
