Ir para o conteúdo principal
Canon PowerShot A550 LCD Screen Replacement
O que você precisa
  1. Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: passo 1, imagem 1 %32 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: passo 1, imagem 2 %32 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: passo 1, imagem 3 %32
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Canon PowerShot A550 LCD Screen Replacement: passo 2, imagem 1 %32
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Canon PowerShot A550 LCD Screen Replacement: passo 3, imagem 1 %32
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Canon PowerShot A550 LCD Screen Replacement: passo 4, imagem 1 %32 Canon PowerShot A550 LCD Screen Replacement: passo 4, imagem 2 %32
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Canon PowerShot A550 LCD Screen Replacement: passo 5, imagem 1 %32
    • The camera should look like this once the front cover is removed.
  6. Canon PowerShot A550 LCD Screen Replacement: passo 6, imagem 1 %32 Canon PowerShot A550 LCD Screen Replacement: passo 6, imagem 2 %32 Canon PowerShot A550 LCD Screen Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Canon PowerShot A550 LCD Screen Replacement: passo 7, imagem 1 %32
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. Canon PowerShot A550 LCD Screen Replacement, LCD Screen: passo 8, imagem 1 %32
    • Use a #00 phillips head screwdriver to remove 2 3.34mm phillips screws holding the LCD screen in place.
  9. Canon PowerShot A550 LCD Screen Replacement: passo 9, imagem 1 %32 Canon PowerShot A550 LCD Screen Replacement: passo 9, imagem 2 %32
    • Use an iPod Opening Tool to lift the brown portion of the connector to unlock it.
    • Slide the data cable out of the connector.
    • Caution: Do not force the data cable out of the connector. It may rip!
  10. Canon PowerShot A550 LCD Screen Replacement: passo 10, imagem 1 %32
    • The LCD screen can now be be removed to be fixed/replaced.
Conclusão
3 outras pessoas executaram este guia.
Precilla Tang
Membro desde: 04/19/11
207 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-6, Regan Spring 2011 Membro de Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 3,894
