Ir para o conteúdo principal
Canon PowerShot A540 LCD Screen Replacement
O que você precisa
  1. Canon PowerShot A540 LCD Screen Replacement, Back Cover: passo 1, imagem 1 %32 Canon PowerShot A540 LCD Screen Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 LCD Screen Replacement: passo 2, imagem 1 %32
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 LCD Screen Replacement: passo 3, imagem 1 %32
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 LCD Screen Replacement: passo 4, imagem 1 %32
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 LCD Screen Replacement: passo 5, imagem 1 %32 Canon PowerShot A540 LCD Screen Replacement: passo 5, imagem 2 %32 Canon PowerShot A540 LCD Screen Replacement: passo 5, imagem 3 %32
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 LCD Screen Replacement, LCD Screen: passo 6, imagem 1 %32 Canon PowerShot A540 LCD Screen Replacement, LCD Screen: passo 6, imagem 2 %32
    • Turn the camera to view the back.
    • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
    • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
  7. Canon PowerShot A540 LCD Screen Replacement: passo 7, imagem 1 %32 Canon PowerShot A540 LCD Screen Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Lift the LCD Screen off of the back to view the attached ribbon cables.
    • Use tweezers to flip the black bar up.
  8. Canon PowerShot A540 LCD Screen Replacement: passo 8, imagem 1 %32 Canon PowerShot A540 LCD Screen Replacement: passo 8, imagem 2 %32 Canon PowerShot A540 LCD Screen Replacement: passo 8, imagem 3 %32
    • Gently pull the big ribbon out.
    • Gently pull the small ribbon out.
    • The small ribbon does not have a bar like the big ribbon.
  9. Canon PowerShot A540 LCD Screen Replacement: passo 9, imagem 1 %32 Canon PowerShot A540 LCD Screen Replacement: passo 9, imagem 2 %32
    • Use tweezers at the top left of the LCD Screen to wedge the top left of the Outer Frame loose.
    • Use your thumb to hold the Outer Frame open.
    • Use the tweezers at the top right of the LCD Screen to wedge the top right of the Outer Frame loose.
  10. Canon PowerShot A540 LCD Screen Replacement: passo 10, imagem 1 %32 Canon PowerShot A540 LCD Screen Replacement: passo 10, imagem 2 %32
    • Slide the LCD Screen out from the Outer Frame.
Conclusão
Carley Fuller
Membro desde: 03/23/15
434 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 7-12, Williams Spring 2015 Membro de Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Membros
Autoria de 20 guias
1Comentário do guia
I wish to purchase a new screen. Where? I feel capable of repair per these instructions and a u tube video.
Geo Schou - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 23
Ao todo: 1,239
