Ir para o conteúdo principal
Canon PowerShot A540 Function Key Motherboard Replacement
O que você precisa
  1. Canon PowerShot A540 Function Key Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 Function Key Motherboard Replacement: passo 2, imagem 1 %32
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 Function Key Motherboard Replacement: passo 3, imagem 1 %32
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 Function Key Motherboard Replacement: passo 4, imagem 1 %32
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 Function Key Motherboard Replacement: passo 5, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 5, imagem 2 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 5, imagem 3 %32
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 Function Key Motherboard Replacement, Function Key Motherboard: passo 6, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement, Function Key Motherboard: passo 6, imagem 2 %32
    • Turn the camera to view the back.
    • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
    • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
  7. Canon PowerShot A540 Function Key Motherboard Replacement: passo 7, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 7, imagem 2 %32
    • Lift the LCD Screen off of the back to view the attached ribbon cables.
    • Use tweezers to flip the black bar up.
  8. Canon PowerShot A540 Function Key Motherboard Replacement: passo 8, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 8, imagem 2 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 8, imagem 3 %32
    • Gently pull the big ribbon out.
    • Gently pull the small ribbon out.
    • The small ribbon does not have a bar like the big ribbon.
  9. Canon PowerShot A540 Function Key Motherboard Replacement: passo 9, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the two (2) 3.0 mm screws with the Phillips head #000 screwdriver.
  10. Canon PowerShot A540 Function Key Motherboard Replacement: passo 10, imagem 1 %32 Canon PowerShot A540 Function Key Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the orange ribbon from the clamp by using a Spudger to push the bar up.
  11. Canon PowerShot A540 Function Key Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the Function Key Motherboard and replace.
    • There is another metal bar that comes off of the SD Card reader when screws are removed.
Conclusão
Cooper Hale
Membro desde: 03/22/15
556 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 7-12, Williams Spring 2015 Membro de Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
Membros da 3
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 714
