Ir para o conteúdo principal
Canon PowerShot A540 Front Cover Replacement
O que você precisa
  1. Canon PowerShot A540 Front Cover Replacement, Back Cover: passo 1, imagem 1 %32 Canon PowerShot A540 Front Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 Front Cover Replacement: passo 2, imagem 1 %32
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 Front Cover Replacement: passo 3, imagem 1 %32
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 Front Cover Replacement: passo 4, imagem 1 %32
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 Front Cover Replacement: passo 5, imagem 1 %32 Canon PowerShot A540 Front Cover Replacement: passo 5, imagem 2 %32 Canon PowerShot A540 Front Cover Replacement: passo 5, imagem 3 %32
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 Front Cover Replacement, Front Cover: passo 6, imagem 1 %32 Canon PowerShot A540 Front Cover Replacement, Front Cover: passo 6, imagem 2 %32
    • Turn the camera to view the front.
    • Remove the lens guard.
    • Press the lens guard's button as you turn the guard counterclockwise.
  7. Canon PowerShot A540 Front Cover Replacement: passo 7, imagem 1 %32
    • Turn the camera to the side left of the LCD screen.
    • Remove the one (1) 4.0 mm screw with the Phillips head #000 screwdriver.
  8. Canon PowerShot A540 Front Cover Replacement: passo 8, imagem 1 %32
    • Remove the front cover gently.
    • When removing the front cover, a thin, black rubber washer may fall off the lens. If it does, make sure to put it back on the lens before reassembly.
Conclusão
Carley Fuller
Membro desde: 03/23/15
434 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 7-12, Williams Spring 2015 Membro de Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
Membros da 3
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Duração total: 1,440
