Pular para o conteúdo principal
Introdução
If your camera will not flash correctly, even with the proper settings, you might need to replace the flash motherboard. After removing the front and back covers, as well as the LCD screen, you will be able to replace the flash motherboard yourself.
Peças
Nenhum componente especificado.
  1. Turn off the camera. Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Open "Card/Batt. Open" Cover.
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Turn the camera to the right side of the LCD screen.
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  6. Gently remove the back cover. Start at the bottom at the corner of the "Card/Batt. Open" Cover. Then move onto the other edges and the top.
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  7. Turn the camera to view the front. Remove the lens guard.
    • Turn the camera to view the front.
    • Remove the lens guard.
    • Press the lens guard's button as you turn the guard counterclockwise.
  8. Turn the camera to the side left of the LCD screen.
    • Turn the camera to the side left of the LCD screen.
    • Remove the one (1) 4.0 mm screw with the Phillips head #000 screwdriver.
  9. Remove the front cover gently.
    • Remove the front cover gently.
    • When removing the front cover, a thin, black rubber washer may fall off the lens. If it does, make sure to put it back on the lens before reassembly.
  10. Turn camera so that you see the top side with the settings wheel.
    • Turn camera so that you see the top side with the settings wheel.
    • Use a Phillips head #000 screwdriver to remove the one (1) 5.0 mm screw at the top as shown.
  11. Remove plastic cover so that you can see the exposed motherboard. Remove plastic cover so that you can see the exposed motherboard.
    • Remove plastic cover so that you can see the exposed motherboard.
  12. Gently pull the ribbon out. Gently pull the ribbon out.
    • Gently pull the ribbon out.
  13. Using a soldering iron and a desoldering wick, carefully disconnect all the wires from where they come into contact with the flash motherboard.
    • Using a soldering iron and a desoldering wick, carefully disconnect all the wires from where they come into contact with the flash motherboard.
    • When all the wires are disconnected, you are ready to replace the flash motherboard.
    • If you have no experience with soldering, do not attempt to replace the flash motherboard. Seek help from someone who has experience with this equipment.
Conclusão
Jared
Membro desde: 23-03-2015
107 reputação
Autoria de 1 guia
Equipe
Baylor, Team 7-12, Williams Spring 2015 Membro de Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Membros
13 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Todo: 457
