Introdução
If your camera will not flash correctly, even with the proper settings, you might need to replace the flash motherboard. After removing the front and back covers, as well as the LCD screen, you will be able to replace the flash motherboard yourself.
O que você precisa
Turn off the camera.
Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
Turn the camera to view the front.
Remove the lens guard.
Press the lens guard's button as you turn the guard counterclockwise.
Turn camera so that you see the top side with the settings wheel.
Use a Phillips head #000 screwdriver to remove the one (1) 5.0 mm screw at the top as shown.
