Ir para o conteúdo principal
Canon PowerShot A480 Battery Replacement
O que você precisa
  1. Canon PowerShot A480 Battery Replacement, Battery: passo 1, imagem 1 %32 Canon PowerShot A480 Battery Replacement, Battery: passo 1, imagem 2 %32 Canon PowerShot A480 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Make sure to fully power off the camera before starting the replacement process.
    • Locate the battery door at the underside of your camera and orient it so that the door points to the right.
    • Gently apply downward pressure to the right edge of the door and slide to the right.
    • Once you hear an audible click, lift up the bay door in the opposite direction till the batteries are fully exposed.
  2. Canon PowerShot A480 Battery Replacement: passo 2, imagem 1 %32 Canon PowerShot A480 Battery Replacement: passo 2, imagem 2 %32 Canon PowerShot A480 Battery Replacement: passo 2, imagem 3 %32
    • Ensure that the contacts for the batteries are free of any corrosion.
    • Gently tip the body of the camera towards your body to slide the batteries out.
    • Slide the batteries out enough to where you are able to grasp both of them for removal.
Conclusão
After obtaining two replacement AA batteries. To reassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Kenneth Robertson
Membro desde: 04/22/19
309 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G5, Cardinal Spring 2019 Membro de UW Tacoma, Team S1-G5, Cardinal Spring 2019
UWT-CARDINAL-S19S1G5
4 Membros
Autoria de 4 guias
1Comentário do guia
Will the normal AA batteries work?
Viswanath harikumar - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 28
Últimos 30 dias: 113
Ao todo: 4,335
