Introdução
Involving removal of the camera casing as well, this guide will help the user remove the LCD screen to repair or replace it.
O que você precisa
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Since the tabs have been lifted, the ribbon should now slide out out easily.
Thank you very much for the good knowledge that I can do by myself.
K201
3 outras pessoas executaram este guia.
2 comentários
Explained in detail, very clear, easy to understand. I just unpacked it for the first time. Still able to do as told. Thank you.
