Ir para o conteúdo principal
Canon PowerShot A4000 IS SD Card Replacement
O que você precisa
  1. Canon PowerShot A4000 IS SD Card Replacement, Reinserting Memory Card: passo 1, imagem 1 %32
    • The inside of your Canon PowerShot A4000 camera should have a picture showing how to reinsert your memory card.
    • Line the memory card up like it is shown in the camera and using your thumb, press down on the card until you hear a click. Your memory card is now back in place and ready for use.
  2. Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: passo 2, imagem 1 %32 Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: passo 2, imagem 2 %32
    • To open the battery compartment where the memory card is stored, refer to the Battery Replacement Guide.
    • The memory card is stored behind the battery on the side opposite of the lens as outlined by the red rectangle in the picture.
    • To remove the memory card, use your thumb to press down on the exposed part of the card.
    • The card will dip down further into the compartment and then you will hear a click as the card is released.
Conclusão
Ansley Gardner
Membro desde: 10/13/14
761 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 1-3, Benson Fall 2014 Membro de Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
Membros da 3
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 801
