Ir para o conteúdo principal
Canon PowerShot A4000 IS Display Replacement
O que você precisa
  1. Canon PowerShot A4000 IS Display Replacement, Removing the Screws: passo 1, imagem 1 %32 Canon PowerShot A4000 IS Display Replacement, Removing the Screws: passo 1, imagem 2 %32
    • First remove the batteries and memory card.
    • Remove the screws for the back cover (circled in red) with a Phillips head screwdriver (PH000) .
  2. Canon PowerShot A4000 IS Display Replacement, Removing the Back Cover: passo 2, imagem 1 %32
    • The back cover can be gently pried off after the screws are removed.
  3. Canon PowerShot A4000 IS Display Replacement, Disconnecting the Screen Frame from the Camera: passo 3, imagem 1 %32 Canon PowerShot A4000 IS Display Replacement, Disconnecting the Screen Frame from the Camera: passo 3, imagem 2 %32
    • Remove the three screws outlined in the pictures.
  4. Canon PowerShot A4000 IS Display Replacement: passo 4, imagem 1 %32 Canon PowerShot A4000 IS Display Replacement: passo 4, imagem 2 %32
    • The ribbon for the screen is folded under the plate. Carefully unfold the ribbon by flipping the screen face down next to the camera.
    • Underneath the plate the connection between the camera and the ribbon can be viewed.
  5. Canon PowerShot A4000 IS Display Replacement, Disconnecting the Ribbon and Removing the Screen: passo 5, imagem 1 %32
    • The metal frame of the screen can be removed using a thin spatula or spudger. After the frame is removed the part of the ribbon connected to the screen is accessible.
Conclusão
Ansley Gardner
Membro desde: 10/13/14
761 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 1-3, Benson Fall 2014 Membro de Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
Membros da 3
Autoria de 17 guias
Um comentário
Completely worthless repair guide! Do not try before reading below!
In Step 4, this guide neglects to mention at all if you raise the plate too high to get to the screen ribbon connector, you will DISCONNECT the ribbon connector “north” (above) it for all the controls and, apparently, power on/off. And if you disconnect this second connector, you are S.O.L. as there is no way to remove the plate completely to reconnect it (the ribbon has nearly zero length/play in it) and the ribbon/control board cannot be completely detached from the plate to give you more length/play as there is a THIRD ribbon connector between the plate and microphone from the control board that dives deep into the innards of the camera.
So because I wasn’t warned and lifted the plate a little too high, I disconnected the controls/power connector with no good way as an average person at home with limited tools or camera repair skills to reseat it, and now have a $20 new LCD screen in a camera that won’t turn on.
Thanks, fixit! >:(
sloe_mule - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,074
