Ir para o conteúdo principal
Canon PowerShot A3400 IS Flash Assembly Replacement
O que você precisa
  1. Canon PowerShot A3400 IS Flash Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 2, imagem 1 %32
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: passo 3, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: passo 3, imagem 2 %32
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 4, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 4, imagem 2 %32
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 5, imagem 1 %32
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 6, imagem 1 %32
    • Remove the 5.00 mm screw from behind the cover.
  7. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 7, imagem 1 %32
    • Make sure the battery cover is open.
  8. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 8, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 8, imagem 2 %32
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  9. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 9, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 9, imagem 2 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 9, imagem 3 %32
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  10. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 10, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 10, imagem 2 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 10, imagem 3 %32
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
  11. Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: passo 11, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: passo 11, imagem 2 %32 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: passo 11, imagem 3 %32
    • Remove the three 5 mm screws
  12. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 12, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 12, imagem 2 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 12, imagem 3 %32
    • Remove the screen by pulling at the two points as shown.
  13. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 13, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 13, imagem 2 %32
    • Remove the metal plate with the plastic opening tool.
  14. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 14, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 14, imagem 2 %32
    • Remove the 5 mm screw
  15. Canon PowerShot A3400 IS Flash Assembly Replacement: passo 15, imagem 1 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 15, imagem 2 %32 Canon PowerShot A3400 IS Flash Assembly Replacement: passo 15, imagem 3 %32
    • Gently pull the flash assembly away.
Conclusão
Uma outra pessoa concluiu este guia.
Emily Pretorius
Membro desde: 01/13/15
325 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-1, Sullivan Winter 2015 Membro de USF Tampa, Team 1-1, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G1
Membros da 3
Autoria de 8 guias
Um comentário
easy to take off but waste of putting it back together..
The Heat - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 21
Duração total: 488
