Introdução
This guide will be used to replace buttons that are non responsive. The buttons are a critical component to any camera. They allow you to access features within the camera. They are required to take photos and even turn the camera on.
O que você precisa
Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
Remove the single philips #00 screw on the button pad which are 2.2mm long. This screw is circled in red in the guide image.
Next, remove the two 2.4mm long screws located in between the LCD screen and the touch pad. These screws will require a Phillips #00 screwdriver.
