Ir para o conteúdo principal
Canon PowerShot A2500 Body Casing and Faceplate Replacement
O que você precisa
  1. Canon PowerShot A2500 Body Casing and Faceplate Replacement, Body Casing and Faceplate: passo 1, imagem 1 %32 Canon PowerShot A2500 Body Casing and Faceplate Replacement, Body Casing and Faceplate: passo 1, imagem 2 %32
    • Remove the knot holding the wrist lanyard onto the camera
  2. Canon PowerShot A2500 Body Casing and Faceplate Replacement: passo 2, imagem 1 %32
    • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
    • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
    • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
  3. Canon PowerShot A2500 Body Casing and Faceplate Replacement: passo 3, imagem 1 %32 Canon PowerShot A2500 Body Casing and Faceplate Replacement: passo 3, imagem 2 %32 Canon PowerShot A2500 Body Casing and Faceplate Replacement: passo 3, imagem 3 %32
    • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
  4. Canon PowerShot A2500 Body Casing and Faceplate Replacement: passo 4, imagem 1 %32 Canon PowerShot A2500 Body Casing and Faceplate Replacement: passo 4, imagem 2 %32 Canon PowerShot A2500 Body Casing and Faceplate Replacement: passo 4, imagem 3 %32
    • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
    • Be careful not to bend the plastic casing to much, as it will crack.
Conclusão
Uma outra pessoa concluiu este guia.
James Hickey
Membro desde: 03/24/15
393 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-4, Duarte Spring 2015 Membro de UMass Dartmouth, Team 3-4, Duarte Spring 2015
UMASSD-DUARTE-S15S3G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 414
