Ir para o conteúdo principal
Canon PowerShot A2300 Front Cover Replacement
O que você precisa
  1. Canon PowerShot A2300 Front Cover Replacement, Front Cover: passo 1, imagem 1 %32
    • Open the A/V Out Digital port cover on the function button side to reveal a screw.
  2. Canon PowerShot A2300 Front Cover Replacement: passo 2, imagem 1 %32 Canon PowerShot A2300 Front Cover Replacement: passo 2, imagem 2 %32 Canon PowerShot A2300 Front Cover Replacement: passo 2, imagem 3 %32
    • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
    • Screws are small and very easily lost.
  3. Canon PowerShot A2300 Front Cover Replacement: passo 3, imagem 1 %32 Canon PowerShot A2300 Front Cover Replacement: passo 3, imagem 2 %32
    • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
    • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
  4. Canon PowerShot A2300 Front Cover Replacement: passo 4, imagem 1 %32
    • Gently lift the bottom of the front cover to roughly a 30 degree angle.
  5. Canon PowerShot A2300 Front Cover Replacement: passo 5, imagem 1 %32
    • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
Conclusão
Uma outra pessoa concluiu este guia.
Ashley Fincher
Membro desde: 03/23/15
477 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 7-14, Williams Spring 2015 Membro de Baylor, Team 7-14, Williams Spring 2015
BU-WILLIAMS-S15S7G14
Membros da 4
Autoria de 10 guias
Um comentário
Are the screws really hard to remove, or is it just me?
Alex Hulinsky - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 566
