Ir para o conteúdo principal
Canon PowerShot A2200 Back Cover Replacement
O que você precisa
  1. Canon PowerShot A2200 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Back Cover Replacement: passo 2, imagem 1 %32
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Back Cover Replacement: passo 3, imagem 1 %32
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Back Cover Replacement: passo 4, imagem 1 %32 Canon PowerShot A2200 Back Cover Replacement: passo 4, imagem 2 %32 Canon PowerShot A2200 Back Cover Replacement: passo 4, imagem 3 %32
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Back Cover Replacement: passo 5, imagem 1 %32 Canon PowerShot A2200 Back Cover Replacement: passo 5, imagem 2 %32 Canon PowerShot A2200 Back Cover Replacement: passo 5, imagem 3 %32
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
Conclusão
Equipe
Baylor, Team 4-5, Williams Spring 2015 Membro de Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 928
