Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If the LCD Display is cracked or not functioning, you can replace it with a new one. Once the case has been disassembled, a new LCD Display can be installed.
O que você precisa
Use a Phillips #00 screwdriver to remove the two screws at the bottom of the camera.
Remove the camera case. Refer to the prerequisite guide Disassembling the Canon PowerShot A200 Case as needed.
Locate the LCD Display. It is the thin, rectangular panel adjacent to the view finder.
Use the Phillips head screwdriver, rotating counter clockwise, to remove the four screws in each corner of the LCD Display. Set the screws aside.
Begin reassembling the camera with the orange strip with the yellow edge.
Align the orange strip on the back half of the camera with its slot on the front part of the camera.
Use the metal tweezers to insert the orange ribbon into the slot. Push the ribbon in as far as it can go into the slot.
Use the metal tweezers to push the black tabs at each side of the slot toward the center. The tabs will hold the orange ribbon in place.
Align the white strip on the back half of the camera with its slot on the front part of the camera.
Use the metal tweezers to insert the white strip into the slot. Push the strip in as far as it can go into the slot.
Use the metal tweezers to push the black tabs at each side of the slot toward the center. The tabs will hold the white strip in place.
Open the outer battery cover.
Use the Phillips head screwdriver, turning clockwise, to fasten two screws on each side of the battery case.
Flip the black battery cover down and press until it is secured by the gray tab.
Use the Phillips head screwdriver, turning clockwise, to fasten two screws on each side of the memory card slot.
Shut the outer battery cover.
Follow the instructions in the prerequisite guide Disassembling the Canon PowerShot A200 Case. Once completed, proceed with installing a new LCD Display.
