Ir para o conteúdo principal
Canon PowerShot A200 Batteries Replacement
  1. Canon PowerShot A200 Batteries Replacement, Outer Battery Cover: passo 1, imagem 1 %32 Canon PowerShot A200 Batteries Replacement, Outer Battery Cover: passo 1, imagem 2 %32
    • Place the camera so the battery cover is facing up, as shown in the picture.
    • Gently push on the outer battery cover until you hear a click, and then release.
  2. Canon PowerShot A200 Batteries Replacement, Inner Battery Cover: passo 2, imagem 1 %32 Canon PowerShot A200 Batteries Replacement, Inner Battery Cover: passo 2, imagem 2 %32
    • To open the inner battery cover, push down on the grey latch until you hear a click, and then release.
    • Remove the dead batteries from the camera.
  3. Canon PowerShot A200 Batteries Replacement, Replacing the Batteries: passo 3, imagem 1 %32
    • After removing the batteries, insert the new batteries in the proper direction.
    • Now push the black, inner cover down until you hear a click to secure the batteries in place.
    • Push down and forward on the outer cover to secure the latch. Your camera will now be fully charged.
Conclusão
Congratulations, you're done.
Ellen Chambers
Membro desde: 01/05/11
231 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-37, Regan Winter 2011 Membro de Cal Poly, Team 7-37, Regan Winter 2011
CPSU-REGAN-W11S7G37
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 2,089
