1. Start by removing the case in the previous guide. The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver. The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver.
    • Start by removing the case in the previous guide.
    • The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Once the spring is clear of the plastic, you can easily push the dowel through with a pin, the end of the tweezers, or a paperclip. Grab the dowel from the other end and pull it out. Grab the dowel from the other end and pull it out.
    • Once the spring is clear of the plastic, you can easily push the dowel through with a pin, the end of the tweezers, or a paperclip.
    • Grab the dowel from the other end and pull it out.
Conclusão
4 outras pessoas concluíram este guia.
Biff Wheeler
762 reputação
4 Guides authored
Hi I have the camera of same model A1000.
Where can I get the battery cover, mine is broken?
Please share the details.
Chennakeshava Reddy Palla - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Todo: 2,583
