Ir para o conteúdo principal
Canon PIXMA MP620B Scanner Light Replacement
O que você precisa
  1. Canon PIXMA MP620B Scanner Light Replacement, Separate the scanner cover from the rest of the lid assembly: passo 1, imagem 1 %32
    • You will have to pry off the glass cover lid. There are no screws that you have to worry about. Just insert a spudger into the crack between the glass lid and black base as shown.
  2. Canon PIXMA MP620B Scanner Light Replacement, Lift the glass cover of the scanner and take out scanner light: passo 2, imagem 1 %32
    • After lifting the glass cover up, the light assembly will come free because it was only held in place by the glass top.
  3. Canon PIXMA MP620B Scanner Light Replacement, Unplug the white wire from the scanner light assembly: passo 3, imagem 1 %32
    • Now that the scanner light assembly is free. Lift it out of the scanner bed and unplug the large white wire that attaches it to the rest of the printer.
Conclusão
5 outras pessoas executaram este guia.
Val Fedorikhin
Membro desde: 10/12/14
860 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-21, Maness Fall 2014 Membro de Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 2,722
