Ir para o conteúdo principal
Canon PIXMA MP190 Ink Cartridge Replacement
  1. Canon PIXMA MP190 Ink Cartridge  Replacement, Turn printer on.: passo 1, imagem 1 %32
    • The printer needs to be on in order to change the ink cartridges.
  2. Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: passo 2, imagem 1 %32 Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: passo 2, imagem 2 %32 Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: passo 2, imagem 3 %32
    • To locate the ink cartridges the paper output tray must be in the lowered position.
    • Next lift the scanning unit until the scanning support is vertical.
    • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  3. Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: passo 3, imagem 1 %32 Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: passo 3, imagem 2 %32 Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: passo 3, imagem 3 %32
    • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
    • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
    • Push down on the front edge of the ink cartridge.
    • Observe the angle at which the ink cartridge is removed.
    • Grasp ink cartridge and pull up and out to remove.
Conclusão
4 outras pessoas executaram este guia.
Garret Wescott
Membro desde: 10/23/14
597 Reputação
Autoria de 4 guias
Equipe
Michigan Tech, Team 1-5, Lauer Fall 2014 Membro de Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 26
Duração total: 9,632
