Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide tells you how to remove and repair or replace the LCD screen and the glass screen in your viewfinder.
O que você precisa
Orient the camera with the hand strap facing you.
Remove the two 4mm #00 Philips screws.
Orient the camera so that the back button panel and viewfinder are facing you.
Push the "Battery Release" button to the side and hold.
Reorient camera so that the playback button panel and empty battery slot are facing you. The edge of the LCD screen should be facing you.
To open the screen, hold the open button shown down and flip the screen open.
Remove the two #00 Philips 4mm screws on the outer edge of the LCD casing.
