Ir para o conteúdo principal
Canon ImageCLASS MF4350d Transformer Replacement
O que você precisa
  1. Canon ImageCLASS MF4350d Transformer Replacement, Canon ImageCLASS MF4350d Remove Front Paneling: passo 1, imagem 1 %32
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Transformer Replacement: passo 2, imagem 1 %32 Canon ImageCLASS MF4350d Transformer Replacement: passo 2, imagem 2 %32
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Transformer Replacement: passo 3, imagem 1 %32 Canon ImageCLASS MF4350d Transformer Replacement: passo 3, imagem 2 %32
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Transformer Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 4, imagem 1 %32 Canon ImageCLASS MF4350d Transformer Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 4, imagem 2 %32 Canon ImageCLASS MF4350d Transformer Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 4, imagem 3 %32
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
  5. Canon ImageCLASS MF4350d Transformer Replacement, Transformer: passo 5, imagem 1 %32 Canon ImageCLASS MF4350d Transformer Replacement, Transformer: passo 5, imagem 2 %32
    • Locate the yellow wire connected to the metal box.
    • Carefully pull the yellow wire from the black connector.
    • Wires may detach completely from plug so tug very gently.
  6. Canon ImageCLASS MF4350d Transformer Replacement: passo 6, imagem 1 %32 Canon ImageCLASS MF4350d Transformer Replacement: passo 6, imagem 2 %32
    • Locate the spring.
    • Unhook the spring on the side of the metal box.
  7. Canon ImageCLASS MF4350d Transformer Replacement: passo 7, imagem 1 %32
    • Unscrew the 10mm screw attaching the metal plate to the printer.
  8. Canon ImageCLASS MF4350d Transformer Replacement: passo 8, imagem 1 %32
    • Lift the transformer out of the printer.
Conclusão
Uma outra pessoa concluiu este guia.
Helena Yanez
Membro desde: 09/29/13
455 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 13-1, Forte Fall 2013 Membro de Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 2,815
