Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate and remove the two 10mm side screws. There is one on each side.
Unhook the plastic panel from the printer starting from the top.
To remove the bottom part of the paneling gently lay the printer on its back.
Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
Lay printer on its left side for better access to the speaker.
Locate the black 7mm screw holding the speaker in place.
Using a Phillips head screw driver, unscrew the 7mm screw.
Locate the red and black wires connected to the speaker.
Undo the white clip holding the wires in place by pinching the tab on the top.
Remove the red and black wires from the wire bundle.
Lift out the speaker
Uma outra pessoa concluiu este guia.
