Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Peças
Nenhum componente especificado.
  1. If at any point you see glass that seems cracked or broken, handle with care.  Broken glass is sharp and can cause serious damage.
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Locate the black and white hinges. Gently lift out the black and white hinges. Gently lift out the black and white hinges.
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Next, locate and remove the four 10mm screws. Next, locate and remove the four 10mm screws. Next, locate and remove the four 10mm screws.
    • Next, locate and remove the four 10mm screws.
  5. Gently, pry off the top plate, starting from the back of the printer.
    • Gently, pry off the top plate, starting from the back of the printer.
  6. After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury. After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
Conclusão
5 outras pessoas concluíram este guia.
Tanner Papenfuss
Membro desde: 30-09-2013
539 Reputação
4 Guias de autoria
equipe
Cal Poly, Team 13-1, Forte Fall 2013 Membro de Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Membros
8 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 8
Últimos 30 dias: 40
Duração total: 3,552
