Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
Locate the black and white hinges.
Gently lift out the black and white hinges.
Gently, pry off the top plate, starting from the back of the printer.
Remove the black component by gently pulling it up from the black scanner belt
Press down on the white release and force it in toward the spring as shown. While you do this, pull the scanner belt out of the track.
Take a new belt and put it in the same way that you took it out.
