Ir para o conteúdo principal
Canon ImageCLASS MF4350d Remove Right Side Paneling
O que você precisa
  1. Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Front Paneling: passo 1, imagem 1 %32
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 2, imagem 1 %32 Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 2, imagem 2 %32
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 3, imagem 1 %32 Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 3, imagem 2 %32
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 4, imagem 1 %32 Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 4, imagem 2 %32 Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 4, imagem 3 %32
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
Conclusão
3 outras pessoas executaram este guia.
Helena Yanez
Membro desde: 09/29/13
455 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 13-1, Forte Fall 2013 Membro de Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
Membros da 5
Autoria de 16 guias
Um comentário
Tore paper when removing jamed paper. A small piece of paper must still be in machine.
Louis Pike McCasland - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 4,081
