Introdução
This is a prerequisite to other guides that deal with the innards of the printer.
Peças
Nenhum componente especificado.
  1. Lift the printer lid up as shown in the photo.
    • Lift the printer lid up as shown in the photo.
  2. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  3. Locate and remove the two 10mm side screws. There is one on each side. Locate and remove the two 10mm side screws. There is one on each side.
    • Locate and remove the two 10mm side screws. There is one on each side.
  4. Unhook the plastic panel from the printer starting from the top. You may need to wiggle the panel a bit to loosen it.
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
Conclusão
Helena Yanez
Membro desde: 29-09-2013
446 Reputation
4 Guias de autoria
Cal Poly, Team 13-1, Forte Fall 2013 Membro de Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Membros
8 Guias de autoria
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 49
