Ir para o conteúdo principal
Canon EOS Rebel XTi Top Casing Replacement
O que você precisa
  1. Canon EOS Rebel XTi Top Casing Replacement, Battery: passo 1, imagem 1 %32
    • Place the camera upside down, and position it to where the back of the camera is visible.
  2. Canon EOS Rebel XTi Top Casing Replacement: passo 2, imagem 1 %32
    • Pull the orange tab to the right to release the primary battery.
  3. Canon EOS Rebel XTi Top Casing Replacement: passo 3, imagem 1 %32
    • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
  4. Canon EOS Rebel XTi Top Casing Replacement, Memory Card: passo 4, imagem 1 %32
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  5. Canon EOS Rebel XTi Top Casing Replacement: passo 5, imagem 1 %32
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  6. Canon EOS Rebel XTi Top Casing Replacement: passo 6, imagem 1 %32
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
  7. Canon EOS Rebel XTi Top Casing Replacement, Top Casing: passo 7, imagem 1 %32 Canon EOS Rebel XTi Top Casing Replacement, Top Casing: passo 7, imagem 2 %32 Canon EOS Rebel XTi Top Casing Replacement, Top Casing: passo 7, imagem 3 %32
    • Remove the single 10 mm JIS #00 shoulder screw.
    • Remove the two 6 mm JIS #00 screws.
  8. Canon EOS Rebel XTi Top Casing Replacement: passo 8, imagem 1 %32
    • Separate the top casing from the electrical components enough to expose the wire harnesses that will need to be disconnected.
    • Ensure to remove the casing gently. There are several wire harnesses connecting the motherboard to components on the casing.
  9. Canon EOS Rebel XTi Top Casing Replacement: passo 9, imagem 1 %32
    • Unplug the yellow connector located on the top of the camera.
  10. Canon EOS Rebel XTi Top Casing Replacement: passo 10, imagem 1 %32
    • Disconnect the red connector located by the USB port.
Conclusão
Uma outra pessoa concluiu este guia.
Nicholas Abate
Membro desde: 08/28/15
656 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 8-6, Eyestone Fall 2015 Membro de USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
Membros da 3
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 1,015
