Ir para o conteúdo principal
Canon EOS Rebel XSi Front Panel Replacement
O que você precisa
  1. Canon EOS Rebel XSi Front Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi Front Panel Replacement: passo 2, imagem 1 %32
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi Front Panel Replacement: passo 3, imagem 1 %32
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi Front Panel Replacement: passo 4, imagem 1 %32
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi Front Panel Replacement: passo 5, imagem 1 %32
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi Front Panel Replacement: passo 6, imagem 1 %32
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi Front Panel Replacement: passo 7, imagem 1 %32
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi Front Panel Replacement: passo 8, imagem 1 %32
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi Front Panel Replacement, Front Panel: passo 9, imagem 1 %32
    • Using the PH000 screwdriver head, remove the four 3mm screws on the front
  10. Canon EOS Rebel XSi Front Panel Replacement: passo 10, imagem 1 %32
    • Remove front grip by gently peeling from the edge towards the center of the camera
  11. Canon EOS Rebel XSi Front Panel Replacement: passo 11, imagem 1 %32
    • Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
  12. Canon EOS Rebel XSi Front Panel Replacement: passo 12, imagem 1 %32
    • Using the PH000 screwdriver, remove the 4mm screw at the bottom of the camera
  13. Canon EOS Rebel XSi Front Panel Replacement: passo 13, imagem 1 %32 Canon EOS Rebel XSi Front Panel Replacement: passo 13, imagem 2 %32 Canon EOS Rebel XSi Front Panel Replacement: passo 13, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
Conclusão
Erik Mork
Membro desde: 01/27/17
602 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 22-10, Maness Winter 2017 Membro de Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,236
