Introdução
This replacement guide shows how to remove the device's front panel. This is necessary to access internal components that are located in the front.
O que você precisa
Squeeze the eyepiece between your index finger and thumb and lift up and off.
Using the PH000 screwdriver head, remove the four 3mm screws on the front
