Ir para o conteúdo principal
Canon EOS Rebel XSi Back Panel Replacement
O que você precisa
  1. Canon EOS Rebel XSi Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi Back Panel Replacement: passo 2, imagem 1 %32
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi Back Panel Replacement: passo 3, imagem 1 %32
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi Back Panel Replacement: passo 4, imagem 1 %32
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi Back Panel Replacement: passo 5, imagem 1 %32
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi Back Panel Replacement: passo 6, imagem 1 %32
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi Back Panel Replacement: passo 7, imagem 1 %32
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi Back Panel Replacement: passo 8, imagem 1 %32
    • Use hands to pry off the back panel.
Conclusão
3 outras pessoas executaram este guia.
Erik Mork
Membro desde: 01/27/17
602 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 22-10, Maness Winter 2017 Membro de Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 51
Ao todo: 1,347
