Introdução
This is a necessary procedure for replacing the lens of the Canon EOS Rebel XS 35mm camera, which is located on the back of the camera, near the top. This guide details how to remove the lens and put a lens back on, whether it's the same lens now fixed, or a new one.
O que você precisa
Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
Using a PH000 screwdriver bit, remove the 2 black screws circled in the picture, which are both 8 mm in length and 1.5 mm in diameter.
