Ir para o conteúdo principal
Canon EOS Rebel XS 35mm Lens Replacement
O que você precisa
  1. Canon EOS Rebel XS 35mm Lens Replacement, Top Cover: passo 1, imagem 1 %32 Canon EOS Rebel XS 35mm Lens Replacement, Top Cover: passo 1, imagem 2 %32
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Lens Replacement: passo 2, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Lens Replacement: passo 3, imagem 1 %32
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Lens Replacement: passo 4, imagem 1 %32 Canon EOS Rebel XS 35mm Lens Replacement: passo 4, imagem 2 %32 Canon EOS Rebel XS 35mm Lens Replacement: passo 4, imagem 3 %32
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  5. Canon EOS Rebel XS 35mm Lens Replacement, Lens: passo 5, imagem 1 %32
    • Using a PH000 screwdriver bit, remove the 2 black screws circled in the picture, which are both 8 mm in length and 1.5 mm in diameter.
  6. Canon EOS Rebel XS 35mm Lens Replacement: passo 6, imagem 1 %32
    • Using your fingers, remove the lens!
Conclusão
christiansvezia
Membro desde: 10/24/18
1.108 Reputação
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 307
