Ir para o conteúdo principal
Canon EOS Rebel T5 SD Card Replacement
O que você precisa
  1. Canon EOS Rebel T5 SD Card Replacement, Battery: passo 1, imagem 1 %32
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 SD Card Replacement: passo 2, imagem 1 %32
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 SD Card Replacement, SD Card: passo 3, imagem 1 %32
  4. Canon EOS Rebel T5 SD Card Replacement: passo 4, imagem 1 %32
    • Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
    • Push in the old SD card until it clicks to remove it and then push in the new card until it clicks into place.
Conclusão
3 outras pessoas executaram este guia.
Austin Tucker
Membro desde: 08/27/15
1.027 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 16-4, Wollert Fall 2015 Membro de USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 50
Duração total: 3,229
