Introdução
If you are going to replace any of the major components of your camera, you will need to first remove the back cover. This guide will teach you how to open up your camera.
O que você precisa
Lay the camera on its back so that the card/battery door is facing you.
Using your fingernail, slide the tab on the battery door up to release the battery door latch.
Turn the camera so that the back is facing to your right.
Remove the 5mm JIS #000 screw above the rubber USB port cover.
5 outras pessoas executaram este guia.
