Ir para o conteúdo principal
Canon EOS Rebel T4i Motherboard Replacement
O que você precisa
  1. Canon EOS Rebel T4i Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Motherboard Replacement: passo 2, imagem 1 %32
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Canon EOS Rebel T4i Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Canon EOS Rebel T4i Motherboard Replacement, Motherboard: passo 3, imagem 2 %32
    • Use the spudger to pry off the rubber grip and reveal the screws.
    • Unscrew the four 5.5mm Torx screws using the Torx T6 screwdriver.
  4. Canon EOS Rebel T4i Motherboard Replacement: passo 4, imagem 1 %32 Canon EOS Rebel T4i Motherboard Replacement: passo 4, imagem 2 %32 Canon EOS Rebel T4i Motherboard Replacement: passo 4, imagem 3 %32
    • Pull off the plastic cover from the viewfinder.
    • Unscrew the two 3.4mm Phillips screws using the Phillips #00 screwdriver.
  5. Canon EOS Rebel T4i Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the following screws from the device using the Phillips #00 screwdriver:
    • Two 3.4mm Phillips head screws.
    • Two 5.9mm Phillips head screw.
  6. Canon EOS Rebel T4i Motherboard Replacement: passo 6, imagem 1 %32
    • One 3.4mm Phillips head screw.
    • One 5.9 mm Phillips head screw.
  7. Canon EOS Rebel T4i Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the rear panel from the camera.
    • Several fragile cables are attached to the inside of the panel, so remove it gently.
  8. Canon EOS Rebel T4i Motherboard Replacement: passo 8, imagem 1 %32 Canon EOS Rebel T4i Motherboard Replacement: passo 8, imagem 2 %32 Canon EOS Rebel T4i Motherboard Replacement: passo 8, imagem 3 %32
    • In the lower right corner of the mother board, detach the blue cable.
    • Then detach the ribbon cable going from the motherboard to the rear panel.
  9. Canon EOS Rebel T4i Motherboard Replacement: passo 9, imagem 1 %32
    • In the upper left corner of the motherboard, remove the small multicolored wire from the motherboard.
  10. Canon EOS Rebel T4i Motherboard Replacement: passo 10, imagem 1 %32 Canon EOS Rebel T4i Motherboard Replacement: passo 10, imagem 2 %32 Canon EOS Rebel T4i Motherboard Replacement: passo 10, imagem 3 %32
    • Use the plastic opening tool to flip up ribbon cable connector.
    • Gently disconnect the ribbon cable by pulling it away from the motherboard.
  11. Canon EOS Rebel T4i Motherboard Replacement: passo 11, imagem 1 %32 Canon EOS Rebel T4i Motherboard Replacement: passo 11, imagem 2 %32
    • In the upper right corner of the motherboard, use the plastic opening tool to remove the clear cable connector from the motherboard.
  12. Canon EOS Rebel T4i Motherboard Replacement: passo 12, imagem 1 %32 Canon EOS Rebel T4i Motherboard Replacement: passo 12, imagem 2 %32
    • Use the plastic opening tool to remove the ribbon cable connecting the image sensor to the motherboard.
  13. Canon EOS Rebel T4i Motherboard Replacement: passo 13, imagem 1 %32 Canon EOS Rebel T4i Motherboard Replacement: passo 13, imagem 2 %32
    • Use the plastic opening tool to push on the indents of the plastic header to disconnect from the motherboard.
    • Make sure all cables are disconnected from the motherboard.
  14. Canon EOS Rebel T4i Motherboard Replacement: passo 14, imagem 1 %32 Canon EOS Rebel T4i Motherboard Replacement: passo 14, imagem 2 %32
    • Remove the following screws from the motherboard using the Phillips #00 screwdriver:
    • Two 3.9mm Phillips head screws.
    • Three 2.9mm Phillips head screws
    • Gently pull the motherboard out of the camera.
Conclusão
16 outras pessoas executaram este guia.
Jordan Rabold
Membro desde: 04/14/14
783 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-33, Maness Spring 2014 Membro de Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
Membros da 4
Autoria de 14 guias
2 comentários
This guide gets an upvote.
It's the first camera disassembly guide I've seen so far on ifixit that includes the single most important precaution: the camera has a body cap fitted to avoid dust, dirt or other objects getting into the mirror box. Bravo!
Flying Dutchman - Responder
Where can we buy the parts?
tjt263 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 59
Duração total: 14,212
