Ir para o conteúdo principal
Canon EOS Rebel T4i LCD Screen Replacement
O que você precisa
  1. Canon EOS Rebel T4i LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i LCD Screen Replacement: passo 2, imagem 1 %32
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Canon EOS Rebel T4i LCD Screen Replacement, LCD Screen: passo 3, imagem 1 %32 Canon EOS Rebel T4i LCD Screen Replacement, LCD Screen: passo 3, imagem 2 %32 Canon EOS Rebel T4i LCD Screen Replacement, LCD Screen: passo 3, imagem 3 %32
    • Remove the six screws on the housing of the LCD.
    • Four 3.1mm JIS screws on the side with the hinge.
    • Two 2.7mm JIS screws
  4. Canon EOS Rebel T4i LCD Screen Replacement: passo 4, imagem 1 %32
    • Remove the plastic back of the LCD.
  5. Canon EOS Rebel T4i LCD Screen Replacement: passo 5, imagem 1 %32 Canon EOS Rebel T4i LCD Screen Replacement: passo 5, imagem 2 %32
    • Unplug the blue cable attached to the back of the LCD.
Conclusão
7 outras pessoas executaram este guia.
Jordan Rabold
Membro desde: 04/14/14
807 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-33, Maness Spring 2014 Membro de Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 Membros
Autoria de 14 guias
2Comentários do guia
where can I buy a replacement LCD screen for my EOS650D camera in Adelaide. Australia
rdmahony4 - Responder
If it helps any, the part number for the LCD screen is CG2-4025. You can also try just searching something like "Canon EOS 650D LCD screen" on eBay to find a replacement screen.
Zephosk -
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 29
Ao todo: 6,226
