Ir para o conteúdo principal
Canon EOS Rebel T4i Battery Replacement
  1. Canon EOS Rebel T4i Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Battery Replacement: passo 2, imagem 1 %32
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
Conclusão
4 outras pessoas executaram este guia.
Nimisha Patel
Membro desde: 04/14/14
185 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-33, Maness Spring 2014 Membro de Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 Membros
Autoria de 14 guias
Um comentário
Black tab on cover of the battery is constantly disengaging either when I am using or in my camera bag therefore battery runs down. Seems like a design fault to me. Anyone else having this problem ? Have been using sticky tape to keep it in place but still have a problem with the cover moving around and disengaging battery. Replacing with a new flimsy one from Canon at minimum cost of £40 is not on - knowing it will only happen again. I have given author 30 points for covering the topic but sadly have no idea how to solve this problem
esther allwood - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 39
Ao todo: 3,286
