Ir para o conteúdo principal
Canon EOS Rebel T3i Motherboard Replacement
O que você precisa
  1. Canon EOS Rebel T3i Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment on the bottom of the camera.
  2. Canon EOS Rebel T3i Motherboard Replacement: passo 2, imagem 1 %32
    • Hook your finger onto the compartment door latch.
    • Open the battery compartment door.
  3. Canon EOS Rebel T3i Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the battery from the compartment.
  4. Canon EOS Rebel T3i Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Canon EOS Rebel T3i Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Peel away the rubber grip on the left side of the camera with your fingers.
    • The grip should feel like a thick sticker as it comes off.
  5. Canon EOS Rebel T3i Motherboard Replacement: passo 5, imagem 1 %32
    • Remove four 3 mm Phillips #000 screws on the left side of the camera.
  6. Canon EOS Rebel T3i Motherboard Replacement: passo 6, imagem 1 %32 Canon EOS Rebel T3i Motherboard Replacement: passo 6, imagem 2 %32 Canon EOS Rebel T3i Motherboard Replacement: passo 6, imagem 3 %32
    • Remove four 3 mm Phillips #000 screws on the bottom of the camera.
  7. Canon EOS Rebel T3i Motherboard Replacement: passo 7, imagem 1 %32
    • Remove two 3 mm Phillips #000 screws on the right side of the camera.
  8. Canon EOS Rebel T3i Motherboard Replacement: passo 8, imagem 1 %32 Canon EOS Rebel T3i Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the back of the camera by lifting from both the left and right sides.
    • Be careful not to break the orange and blue cables connecting the back panel of the camera to the motherboard.
  9. Canon EOS Rebel T3i Motherboard Replacement: passo 9, imagem 1 %32
    • Disconnect the orange cable at the bottom of the camera by gently pinching with your fingers.
  10. Canon EOS Rebel T3i Motherboard Replacement: passo 10, imagem 1 %32
    • Detach the blue cable by sliding the pointed end of a spudger between the motherboard and the silver prongs connected to the cable.
  11. Canon EOS Rebel T3i Motherboard Replacement: passo 11, imagem 1 %32
    • Locate the cable on the top left corner of the motherboard.
    • Pinch the round, white connector with tweezers and gently remove the cable.
  12. Canon EOS Rebel T3i Motherboard Replacement: passo 12, imagem 1 %32 Canon EOS Rebel T3i Motherboard Replacement: passo 12, imagem 2 %32
    • With tweezers, pinch the ends of the remaining orange ribbon cables, and gently pull these ends off of the motherboard.
    • Leave the other end of all ribbon cables attached to their components.
  13. Canon EOS Rebel T3i Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the five 4 mm Phillips #000 screws.
  14. Canon EOS Rebel T3i Motherboard Replacement: passo 14, imagem 1 %32
    • Gently lift the motherboard away from the camera.
Conclusão
19 outras pessoas executaram este guia.
Natalie Crock
Membro desde: 08/27/15
752 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 5-2, Blackwell Fall 2015 Membro de USF Tampa, Team 5-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G2
Membros da 4
Autoria de 10 guias
7 comentários
Publicación muy esmerada y didáctica, gracias.
Japons - Responder
There was one huge step left out. On the T3i there is a fiber optic cable connection on the underside, top right hand side of the motherboard. If you don't reconnect this before reassembly your camera won't work. It is difficult to make sure both this cable and the adjacent white round-wire cable are connected before putting the motherboard back in place.
Albert Einstein - Responder
How do you connect it?
art.w.abate -
I concur with Albert Einstein. It was very difficult. This should be mentioned int the steps, not reserved for the comments!
Raymond Pedersen - Responder
Yes, 15 step. to make it easier to connect the optical cable and the second rear cable is better to remove the top cover
Evgeny Rozalenok - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 54
Duração total: 13,340
