Ir para o conteúdo principal
Canon EOS Rebel T3i Front Casing Replacement
O que você precisa
  1. Canon EOS Rebel T3i Front Casing Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment on the bottom of the camera.
  2. Canon EOS Rebel T3i Front Casing Replacement: passo 2, imagem 1 %32
    • Hook your finger onto the compartment door latch.
    • Open the battery compartment door.
  3. Canon EOS Rebel T3i Front Casing Replacement: passo 3, imagem 1 %32
    • Remove the battery from the compartment.
  4. Canon EOS Rebel T3i Front Casing Replacement, Front Casing: passo 4, imagem 1 %32
    • Remove the two 3 mm Phillips #000 screws.
    • Some variations of this camera may have one 3mm and one 6mm screws.
    • If the rubber eyepiece mount is still on the camera, remove it before attempting to separate the case halves.
  5. Canon EOS Rebel T3i Front Casing Replacement: passo 5, imagem 1 %32
    • Remove the three 3 mm Phillips #000 screws.
    • Remove the single 6 mm Phillips #000 screw.
    • Some variation of this camera have two 3mm and two 6mm screws
  6. Canon EOS Rebel T3i Front Casing Replacement: passo 6, imagem 1 %32
    • Peel back the grip tape with your fingernail.
    • Depending on the age of the camera, the grip tape will stick back in place with no need for extra glue.
  7. Canon EOS Rebel T3i Front Casing Replacement: passo 7, imagem 1 %32
    • Remove the four 5 mm Phillips #000 screws.
    • Some variation of this model may have three 5mm screws and one 6mm
  8. Canon EOS Rebel T3i Front Casing Replacement: passo 8, imagem 1 %32
    • Slide off the right side of the camera.
    • Do not completely separate the body yet. There are still wires that must be disconnected. If the body is pulled apart too quickly, it may cause damage.
  9. Canon EOS Rebel T3i Front Casing Replacement: passo 9, imagem 1 %32
    • Lift off the USB cover.
    • Do not completely remove the back of the camera. There are still wires that must be disconnected. Removing the back too quickly may cause damage to wires.
    • When lifting the cover, the only thing resisting your tug is the plug cover stopper. Just pull, you'll be fine.
    • When replacing it, having the covers snug on the plate will make it easier to push the whole cover on
  10. Canon EOS Rebel T3i Front Casing Replacement: passo 10, imagem 1 %32
    • After separating the back, gently lift off one side of the light blue wire with the spudger until the connector is totally removed.
    • You may feel a slight resistance as you pull the top of the back cover off, it will click but that is fine.
  11. Canon EOS Rebel T3i Front Casing Replacement: passo 11, imagem 1 %32
    • With the spudger, remove the orange ribbon cable leading to the circuit board from the back of the camera.
  12. Canon EOS Rebel T3i Front Casing Replacement: passo 12, imagem 1 %32
    • Remove the two 6 mm Phillips #000 screws.
  13. Canon EOS Rebel T3i Front Casing Replacement: passo 13, imagem 1 %32
    • Remove the single 6 mm and two 3 mm Phillips #000 screws.
  14. Canon EOS Rebel T3i Front Casing Replacement: passo 14, imagem 1 %32
    • Use the spudger to lift the plastic under the tripod mount.
  15. Canon EOS Rebel T3i Front Casing Replacement: passo 15, imagem 1 %32
    • Lift the front cover off.
Conclusão
5 outras pessoas executaram este guia.
Natalie Crock
Membro desde: 08/27/15
752 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 5-2, Blackwell Fall 2015 Membro de USF Tampa, Team 5-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G2
Membros da 4
Autoria de 10 guias
Um comentário
when I connect and lens the camera replies that the lens is properly connected. One of the copper lens connectors on the camera’s body is kinda greenish rather than gold, so I wanna clean it, how to do that?
Tensor Elmikawy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 37
Duração total: 6,497
