Ir para o conteúdo principal
Canon EOS Rebel T2i Tripod Mount Replacement
O que você precisa
  1. Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: passo 1, imagem 1 %32 Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: passo 1, imagem 2 %32
    • Turn off camera using the power button on the top of the camera.
    • On the bottom of the camera, open the battery door and remove the battery.
  2. Canon EOS Rebel T2i Tripod Mount Replacement: passo 2, imagem 1 %32
    • Remove the 7 screws from the bottom of the camera using a Phillips screwdriver
  3. Canon EOS Rebel T2i Tripod Mount Replacement: passo 3, imagem 1 %32
    • Remove the two screws on the right side of the camera.
  4. Canon EOS Rebel T2i Tripod Mount Replacement: passo 4, imagem 1 %32
    • Remove 1 screw from the left side of the camera.
    • Inside the rubber door, remove the two silver screws.
  5. Canon EOS Rebel T2i Tripod Mount Replacement: passo 5, imagem 1 %32
    • Remove the two black screws on the front of the camera just above the lens mounting ring.
    • NOTE: Do not remove any of the silver screws on the lens mount ring. This could cause problems with auto focussing features.
  6. Canon EOS Rebel T2i Tripod Mount Replacement: passo 6, imagem 1 %32 Canon EOS Rebel T2i Tripod Mount Replacement: passo 6, imagem 2 %32
    • Using the spudger and plastic opening tool, pry the back of the camera loose.
  7. Canon EOS Rebel T2i Tripod Mount Replacement: passo 7, imagem 1 %32
    • Using the spudger and plastic opening tool, pry the bottom of the front panel of the camera over the tripod mount.
  8. Canon EOS Rebel T2i Tripod Mount Replacement: passo 8, imagem 1 %32 Canon EOS Rebel T2i Tripod Mount Replacement: passo 8, imagem 2 %32
    • The screws holding the tripod mount are now exposed.
    • Remove the screws securing the tripod mount
    • With the screws removed, the tripod mount can now be easily pulled free.
Conclusão
Jacob Jaskolka
Membro desde: 03/30/15
745 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 1-1, Shastany Spring 2015 Membro de UMass Dartmouth, Team 1-1, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G1
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,679
