Introdução
This guide covers how to disassemble the I/F Terminal Cover, which is the cover that is found over the I/O ports on the left side of the camera. This includes both the plastic cover and the rubber cap that goes over it. Disassembly and replacement of these parts is very straight forward and simple to do.
O que você precisa
Pry open the rubber I/F terminal cap with your finger.
Remove the two M1.7x2.5mm JIS #000 screws that are underneath the I/F terminal cap.
Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
