Ir para o conteúdo principal
Canon EOS Rebel T2i Clock Battery Replacement
O que você precisa
  1. Canon EOS Rebel T2i Clock Battery Replacement, Clock Battery: passo 1, imagem 1 %32 Canon EOS Rebel T2i Clock Battery Replacement, Clock Battery: passo 1, imagem 2 %32
    • This is not reversible and your camera will look like this forever after snapping off the plastic clip.
    • Unfortunately I don't have a before picture, but the battery is under a plastic cover that you have to snap off.
    • I did not take the 2nd picture, but it is an example of what it looks like here before breaking the plastic. Source:
    • Replacing internal backup battery of Canon EOS Rebel T3i camera
  2. Canon EOS Rebel T2i Clock Battery Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Can use thin flat-head screwdriver or tweezers to pry off the cover and reveal the battery slot.
  3. Canon EOS Rebel T2i Clock Battery Replacement: passo 3, imagem 1 %32 Canon EOS Rebel T2i Clock Battery Replacement: passo 3, imagem 2 %32
    • Can now see the battery and any model numbers on it. On my camera it is labeled "MS614SE"
    • Use a thin flat-head screwdriver or your tweezers to get the old battery out.
    • Slide in the new one and push it in with your finger.
Linha de Chegada
3 outras pessoas executaram este guia.
Um comentário
Hi, Great help!
Where can I buy the replacement MS614SE?
Kam
Kam Lam - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 82
Ao todo: 2,489
