Ir para o conteúdo principal
Canon EOS Rebel T1i Front Screen Replacement
O que você precisa
  1. Canon EOS Rebel T1i Front Screen Replacement, Front Screen: passo 1, imagem 1 %32
    • Clean the broken or cracked screen as best as possible.
    • Place the suction cup on the damaged screen.
  2. Canon EOS Rebel T1i Front Screen Replacement: passo 2, imagem 1 %32 Canon EOS Rebel T1i Front Screen Replacement: passo 2, imagem 2 %32
    • While holding the suction cup flat against the camera screen, suction the two together by pinching the orange handles to meet at the center.
  3. Canon EOS Rebel T1i Front Screen Replacement: passo 3, imagem 1 %32 Canon EOS Rebel T1i Front Screen Replacement: passo 3, imagem 2 %32 Canon EOS Rebel T1i Front Screen Replacement: passo 3, imagem 3 %32
    • Grab the handle of the suction cup and gently lift it up at an angle, as demonstrated in the picture.
    • Remove the plastic screen from the camera.
    • Release the broken screen by pulling down the lever of the suction cup.
Conclusão
5 outras pessoas executaram este guia.
Michael Peck
Membro desde: 04/14/14
167 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 3-41, Maness Spring 2014 Membro de Cal Poly, Team 3-41, Maness Spring 2014
CPSU-MANESS-S14S3G41
Membros da 4
Autoria de 10 guias
Um comentário
Be sure to measure the size of your screen before buying the suction cups. I got the heavy-duty ones and then found that they were too big for my Rebel T1i screen.
cmorris - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 5,390
