Ir para o conteúdo principal
Canon EOS Rebel T1i Camera Battery Notch Replacement
O que você precisa
  1. Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: passo 1, imagem 1 %32 Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: passo 1, imagem 2 %32
    • Locate the side of camera with the HDMI port.
    • Unscrew the 7mm with a #00 Phillips screw driver.
  2. Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 2, imagem 1 %32 Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 2, imagem 2 %32
    • Use your fingers to gently detach the plastic component from the camera
  3. Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 3, imagem 1 %32 Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 3, imagem 2 %32 Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 3, imagem 3 %32
    • Unscrew the bottom three 4mm screws with a #00 Phillips screwdriver.
  4. Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 4, imagem 1 %32
    • Unscrew the inner 4mm screw with a #00 Phillips screwdriver.
  5. Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 5, imagem 1 %32 Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 5, imagem 2 %32
    • Unscrew the top 7mm screw on the right side of the camera.
    • Unscrew the bottom 4 mm screw on the right side of the camera.
  6. Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 6, imagem 1 %32 Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 6, imagem 2 %32 Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 6, imagem 3 %32
    • Use the plastic opening tool to pry open the entire back panel.
    • Use your fingers to pull off the back panel.
  7. Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 7, imagem 1 %32 Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 7, imagem 2 %32 Canon EOS Rebel T1i Camera Battery Notch Replacement: passo 7, imagem 3 %32
    • Now that the panel is off, unscrew the 9mm screw holding the battery notch in.
    • Use the pliers (or your fingers) to take off the white notch.
    • There is a spring underneath the battery notch. Do not lose this spring or let it fall off.
Conclusão
4 outras pessoas executaram este guia.
Jonathan Lin
Membro desde: 04/14/14
548 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 3-41, Maness Spring 2014 Membro de Cal Poly, Team 3-41, Maness Spring 2014
CPSU-MANESS-S14S3G41
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Duração total: 3,185
