Introdução
This guide shows you how to install the top panel of the camera.
O que você precisa
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Turn Camera over.
Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
Uma outra pessoa concluiu este guia.
